cancel
Showing results for
Show  only  | Search instead for
Did you mean:
Announcements
What’s new: end-to-end encryption, Replay and Dash updates. Find out more about these updates, new features and more here.
Create, upload, and share
Find help to solve issues with creating, uploading, and sharing files and folders in Dropbox. Get support and advice from the Dropbox Community.
cancel
Showing results for
Did you mean:
Upload button does not work (Web).
Annie P
Helpful | Level 5
Go to solution
Upload button does not react after clicking on it. Could you help please?
1 Accepted Solution
Accepted Solutions
BenDBX
Community Manager
Go to solution
Hi Everybody,
A fix has been implemented. If you're still experiencing an inability to upload, reply here and I'll pass that info on.
Thanks,
Ben
View solution in original post
23 Replies 23
Megan
Dropbox Staff
Go to solution
Hey @Annie P, I hope you're doing well!
It sounds like your browser isn't able to process the upload button for some reason. Could you try switching browsers to see if this helps?
Otherwise, you can try using incognito/private browsing mode without any extensions running, clearing your cache and even resetting your browser entirely.
Those are the first steps in troubleshooting any possible browser issue.
Let me know of any updates!
Megan
Community Moderator @ Dropbox
dropbox.com/support
Heart Did this post help you? If so, give it a Like below to let us know.
:arrows_counterclockwise: Need help with something else? Ask me a question!
:pushpin: Find Tips & Tricks Discover more ways to use Dropbox here!
:arrows_counterclockwise: Interested in Community Groups? Click here to join!
tict0c
New member | Level 2
Go to solution
Same thing happening to me. Started yesterday. I am using Chrome. I could get around the problem yesterday by leaving the folder and coming back to it and it would let me upload but today that is not working.
LF Law Firm
Explorer | Level 4
Go to solution
Also having this issue; drag and drop uploading is still working fine, and the upload button will work if the page is refreshed.
Chrome browser. Working through the common browser troubleshooting steps now.
Megan
Dropbox Staff
Go to solution
Hey guys, thanks for bringing this up!
Let me know if you notice this only when using Chrome, or on a different browser too.
Using the steps I provided above, might also help us isolate the issue.
Thanks a bunch!
Megan
dropbox.com/support
jh24
Explorer | Level 4
Go to solution
Upload button does not work for me or by boss.. tried 3 different browsers and none of them worked.  I emailed for help with a ticket and even though they emailed me back none of the suggestions are working. For now I am dragging the items in.
Megan
Dropbox Staff
Go to solution
Hi @jh24, sorry to hear about that!
Would you mind sending over the ticket number reference, in order for me to locate it on our system?
Our status page doesn't report some issue, that's why I'm asking.
Megan
dropbox.com/support
jh24
Explorer | Level 4
Go to solution
Ticket # 23528280
Megan
Dropbox Staff
Go to solution
Thanks for that @jh24!
I've pinged the agent working on this, and they should reply back as soon as possible.
Hang tight, and thank you for your patience!
Megan
dropbox.com/support
jh24
Explorer | Level 4
Go to solution
Thank you!
Need more support?
Who's talking
Top contributors to this post
  • User avatar
    ricf Helpful | Level 5
  • User avatar
    BenDBX Community Manager
  • User avatar
    Walter Dropbox Staff
  • User avatar
    Annie P Helpful | Level 5
What do Dropbox user levels mean?
